How to only backup configuration data?
xpertech
Post by xpertech »
Is it possible to only backup NagiosXI configuration without backup useless history data?
if yes, when restore, is it the same process?
benjaminsmith
Re: How to only backup configuration data?
Post by benjaminsmith »
Hello @xpertech,
Nagios XI will automatically backup configuration files when you make changes and you can download them as well. Go to Admin > Monitoring Config > Config Snapshots.
Let me know if you have further questions.
