While uploading the plugin to nagios exchange, by mistake clicked submit without the link to plugin github page and other details. How can I resubmit or update the submitted plugin. How can I communicate with the administrator who reviews the plugin.
Resubmit/update a plugin submitted for review
Re: Resubmit/update a plugin submitted for review
I can assist you with this, can you send me your Exchange username as well as the plugin github page and other details.
I will check the listing and once approved you can make any additional modifications.
Here are the details
Nagios exchange username: cohesity-dev
Plugin directory: Plugins/ Backup and Recovery
Plugin Name: Check Cohesity
Current Version: 1.0.0
Last Release Date: 4th Oct, 2019
Compatible with: Nagios 4.x
Summary:
This is a Cohesity Nagios plugin that monitors Cohesity clusters. The plugin has scripts to monitor alerts, meta storage, storage, cluster nodes, unprotected objects and protection runs.
Download URL: https://github.com/cohesity/cohesity-nagios-plugin
License: GPL
Thanks!
Summary:
License: GPL
Thanks!
