Hi everyone,
I am trying to get Nagios Core up and running on Ubuntu but am having a hard time actually getting it to function.
I'm running Ubuntu Ver. 18
and Installed Nagios Core: 4.4.5
I did a clean install using Nagios' website and once it is installed it wont start. If i run "sudo systemctl start nagios.service" I get:
Job for nagios.service failed because the control process exited with error code.
See "systemctl status nagios.service" and "journalctl -xe" for details.
Here is "systemctl status nagios.service":
nagios.service - Nagios Core Monitoring Daemon
Loaded: loaded (/etc/systemd/system/nagios.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2019-10-07 14:33:13 PDT; 6s ago
Process: 2819 ExecStart=/usr/lib/systemd/scripts/nagios start (code=exited, status=203/EXEC)
Oct 07 14:33:13 Lab systemd[1]: Starting Nagios Core Monitoring Daemon...
Oct 07 14:33:13 Lab systemd[2819]: nagios.service: Failed to execute command: No such file or dire
Oct 07 14:33:13 Lab systemd[2819]: nagios.service: Failed at step EXEC spawning /usr/lib/systemd/s
Oct 07 14:33:13 Lab systemd[1]: nagios.service: Control process exited, code=exited status=203
Oct 07 14:33:13 Lab systemd[1]: nagios.service: Failed with result 'exit-code'.
Oct 07 14:33:13 Lab systemd[1]: Failed to start Nagios Core Monitoring Daemon.
And "journalctl -xe":
-- Unit nagios.service has begun starting up.
-- Subject: Process /usr/lib/systemd/scripts/nagios could not be executed
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- The process /usr/lib/systemd/scripts/nagios could not be executed and failed.
-- The error number returned by this process is 2.
-- Subject: Unit nagios.service has failed
-- Unit nagios.service has failed.
Nagios is Failing to Start
Re: Nagios is Failing to Start
First, let's run a verification of the Nagios configurations to see if there are any errors. Run the following as root and post the output here so we can view it.
If you see any errors, that would stop the process from starting so fix the errors and try starting the nagios process again.
/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfgBe sure to check out our Knowledgebase for helpful articles and solutions!
