Looks like it's failing to create new indexes. If I delete the broken index it will go yellow but then as soon as the next message is received it returns to red.
curl -XGET 'http://localhost:9200/_cluster/health?pretty=true'
"cluster_name" : "3384d7f1-dc67-40b6-a18e-78ce15c78ec7",
"status" : "red",
"timed_out" : false,
"number_of_nodes" : 4,
"number_of_data_nodes" : 4,
"active_primary_shards" : 67,
"active_shards" : 67,
"relocating_shards" : 0,
"initializing_shards" : 0,
"unassigned_shards" : 77,
"delayed_unassigned_shards" : 0,
"number_of_pending_tasks" : 0,
"number_of_in_flight_fetch" : 0
curl -XGET localhost:9200/_cat/shards?h=index,shard,prirep,state,unassigned.reason| grep UNASSIGNED
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 7776 100logstash-2019.10.03 2 r UNASSIGNED NODE_LEFT
777logstash-2019.10.03 0 r UNASSIGNED NODE_LEFT
6 logstash-2019.10.03 3 r UNASSIGNED NODE_LEFT
0 logstash-2019.10.03 1 r UNASSIGNED NODE_LEFT
logstash-2019.10.03 4 r UNASSIGNED NODE_LEFT
0 9logstash-2019.10.04 4 r UNASSIGNED NODE_LEFT
5821logstash-2019.10.04 0 r UNASSIGNED NODE_LEFT
logstash-2019.10.04 3 r UNASSIGNED NODE_LEFT
0logstash-2019.10.04 1 r UNASSIGNED NODE_LEFT
--:logstash-2019.10.04 2 r UNASSIGNED NODE_LEFT
--:-logstash-2019.10.01 2 r UNASSIGNED NODE_LEFT
- --logstash-2019.10.01 0 r UNASSIGNED NODE_LEFT
:--logstash-2019.10.01 3 r UNASSIGNED NODE_LEFT
:--logstash-2019.10.01 1 r UNASSIGNED NODE_LEFT
--logstash-2019.10.01 4 r UNASSIGNED NODE_LEFT
:--logstash-2019.09.27 4 r UNASSIGNED NODE_LEFT
:--logstash-2019.09.27 0 r UNASSIGNED NODE_LEFT
97logstash-2019.09.27 3 r UNASSIGNED NODE_LEFT
200logstash-2019.09.27 1 r UNASSIGNED NODE_LEFT
logstash-2019.09.27 2 r UNASSIGNED NODE_LEFT
logstash-2019.10.02 4 r UNASSIGNED NODE_LEFT
logstash-2019.10.02 0 r UNASSIGNED NODE_LEFT
logstash-2019.10.02 3 r UNASSIGNED NODE_LEFT
logstash-2019.10.02 1 r UNASSIGNED NODE_LEFT
logstash-2019.10.02 2 r UNASSIGNED NODE_LEFT
kibana-int 2 r UNASSIGNED NODE_LEFT
kibana-int 0 r UNASSIGNED NODE_LEFT
kibana-int 3 r UNASSIGNED NODE_LEFT
kibana-int 1 r UNASSIGNED NODE_LEFT
kibana-int 4 r UNASSIGNED NODE_LEFT
logstash-2019.09.28 2 r UNASSIGNED NODE_LEFT
logstash-2019.09.28 0 r UNASSIGNED NODE_LEFT
logstash-2019.09.28 3 r UNASSIGNED NODE_LEFT
logstash-2019.09.28 1 r UNASSIGNED NODE_LEFT
logstash-2019.09.28 4 r UNASSIGNED NODE_LEFT
logstash-2019.10.07 4 r UNASSIGNED NODE_LEFT
logstash-2019.10.07 0 r UNASSIGNED NODE_LEFT
logstash-2019.10.07 3 r UNASSIGNED NODE_LEFT
logstash-2019.10.07 1 r UNASSIGNED NODE_LEFT
logstash-2019.10.07 2 r UNASSIGNED NODE_LEFT
logstash-2019.10.08 2 r UNASSIGNED INDEX_CREATED
logstash-2019.10.08 2 p UNASSIGNED INDEX_CREATED
logstash-2019.10.08 0 r UNASSIGNED INDEX_CREATED
logstash-2019.10.08 0 p UNASSIGNED INDEX_CREATED
logstash-2019.10.08 3 r UNASSIGNED INDEX_CREATED
logstash-2019.10.08 3 p UNASSIGNED INDEX_CREATED
logstash-2019.10.08 1 r UNASSIGNED INDEX_CREATED
logstash-2019.10.08 1 p UNASSIGNED INDEX_CREATED
logstash-2019.10.08 4 r UNASSIGNED INDEX_CREATED
logstash-2019.10.08 4 p UNASSIGNED INDEX_CREATED
logstash-2019.10.05 2 r UNASSIGNED NODE_LEFT
logstash-2019.10.05 0 r UNASSIGNED NODE_LEFT
logstash-2019.10.05 3 r UNASSIGNED NODE_LEFT
logstash-2019.10.05 1 r UNASSIGNED NODE_LEFT
logstash-2019.10.05 4 r UNASSIGNED NODE_LEFT
logstash-2019.10.06 4 r UNASSIGNED NODE_LEFT
logstash-2019.10.06 0 r UNASSIGNED NODE_LEFT
logstash-2019.10.06 3 r UNASSIGNED NODE_LEFT
logstash-2019.10.06 1 r UNASSIGNED NODE_LEFT
logstash-2019.10.06 2 r UNASSIGNED NODE_LEFT
logstash-2019.09.30 4 r UNASSIGNED NODE_LEFT
logstash-2019.09.30 0 r UNASSIGNED NODE_LEFT
logstash-2019.09.30 3 r UNASSIGNED NODE_LEFT
logstash-2019.09.30 1 r UNASSIGNED NODE_LEFT
logstash-2019.09.30 2 r UNASSIGNED NODE_LEFT
logstash-2019.09.29 4 r UNASSIGNED NODE_LEFT
logstash-2019.09.29 0 r UNASSIGNED NODE_LEFT
logstash-2019.09.29 3 r UNASSIGNED NODE_LEFT
logstash-2019.09.29 1 r UNASSIGNED NODE_LEFT
logstash-2019.09.29 2 r UNASSIGNED NODE_LEFT
nagioslogserver 0 r UNASSIGNED NODE_LEFT
nagioslogserver_log 4 r UNASSIGNED NODE_LEFT
nagioslogserver_log 0 r UNASSIGNED NODE_LEFT
nagioslogserver_log 3 r UNASSIGNED NODE_LEFT
nagioslogserver_log 1 r UNASSIGNED NODE_LEFT
nagioslogserver_log 2 r UNASSIGNED NODE_LEFT
nagioslogserver_history 0 r UNASSIGNED NODE_LEFT
logstash-2019.10.03 2 p STARTED
logstash-2019.10.03 0 p STARTED
logstash-2019.10.03 3 p STARTED
logstash-2019.10.03 1 p STARTED
logstash-2019.10.03 4 p STARTED
logstash-2019.10.04 4 p STARTED
logstash-2019.10.04 0 p STARTED
logstash-2019.10.04 3 p STARTED
logstash-2019.10.04 1 p STARTED
logstash-2019.10.04 2 p STARTED
logstash-2019.10.01 2 p STARTED
logstash-2019.10.01 0 p STARTED
logstash-2019.10.01 3 p STARTED
logstash-2019.10.01 1 p STARTED
logstash-2019.10.01 4 p STARTED
logstash-2019.09.27 4 p STARTED
logstash-2019.09.27 0 p STARTED
logstash-2019.09.27 3 p STARTED
logstash-2019.09.27 1 p STARTED
logstash-2019.09.27 2 p STARTED
logstash-2019.10.02 4 p STARTED
logstash-2019.10.02 0 p STARTED
logstash-2019.10.02 3 p STARTED
logstash-2019.10.02 1 p STARTED
logstash-2019.10.02 2 p STARTED
kibana-int 2 p STARTED
kibana-int 0 p STARTED
kibana-int 3 p STARTED
kibana-int 1 p STARTED
kibana-int 4 p STARTED
logstash-2019.09.28 2 p STARTED
logstash-2019.09.28 0 p STARTED
logstash-2019.09.28 3 p STARTED
logstash-2019.09.28 1 p STARTED
logstash-2019.09.28 4 p STARTED
logstash-2019.10.07 4 p STARTED
logstash-2019.10.07 0 p STARTED
logstash-2019.10.07 3 p STARTED
logstash-2019.10.07 1 p STARTED
logstash-2019.10.07 2 p STARTED
logstash-2019.10.05 2 p STARTED
logstash-2019.10.05 0 p STARTED
logstash-2019.10.05 3 p STARTED
logstash-2019.10.05 1 p STARTED
logstash-2019.10.05 4 p STARTED
logstash-2019.10.06 4 p STARTED
logstash-2019.10.06 0 p STARTED
logstash-2019.10.06 3 p STARTED
logstash-2019.10.06 1 p STARTED
logstash-2019.10.06 2 p STARTED
logstash-2019.09.30 4 p STARTED
logstash-2019.09.30 0 p STARTED
logstash-2019.09.30 3 p STARTED
logstash-2019.09.30 1 p STARTED
logstash-2019.09.30 2 p STARTED
logstash-2019.09.29 4 p STARTED
logstash-2019.09.29 0 p STARTED
logstash-2019.09.29 3 p STARTED
logstash-2019.09.29 1 p STARTED
logstash-2019.09.29 2 p STARTED
nagioslogserver 0 p STARTED
nagioslogserver_log 4 p STARTED
nagioslogserver_log 0 p STARTED
nagioslogserver_log 3 p STARTED
nagioslogserver_log 1 p STARTED
nagioslogserver_log 2 p STARTED
nagioslogserver_history 0 p STARTED
Cluster status Red after upgrade
Re: Cluster status Red after upgrade
lets restart elasticsearch on each instance
then give it a bit of time to catch up
If you still have issues, lets run the following and return the output for each instance
service elasticsearch restartIf you still have issues, lets run the following and return the output for each instance
df -hRe: Cluster status Red after upgrade
How long are we talking on waiting for it to recover? I'm not seeing any difference after the restart waiting about 15 minutes.
node1:
devtmpfs 16G 0 16G 0% /dev
tmpfs 16G 0 16G 0% /dev/shm
tmpfs 16G 25M 16G 1% /run
tmpfs 16G 0 16G 0% /sys/fs/cgroup
/dev/sda3 105G 5.5G 94G 6% /
/dev/md0 1.8T 1.6T 161G 91% /store
/dev/sda2 976M 204M 705M 23% /boot
/dev/sda1 1022M 12M 1011M 2% /boot/efi
tmpfs 3.2G 0 3.2G 0% /run/user/41442
tmpfs 3.2G 0 3.2G 0% /run/user/15843
node2:
devtmpfs 32G 0 32G 0% /dev
tmpfs 32G 0 32G 0% /dev/shm
tmpfs 32G 25M 32G 1% /run
tmpfs 32G 0 32G 0% /sys/fs/cgroup
/dev/sda3 105G 6.3G 93G 7% /
/dev/md0 1.8T 1.6T 170G 91% /store
tmpfs 6.3G 0 6.3G 0% /run/user/15843
tmpfs 6.3G 0 6.3G 0% /run/user/41442
node3:
tmpfs 32G 3.2G 29G 10% /run
/dev/sda4 104G 6.3G 93G 7% /
/dev/sda2 976M 197M 713M 22% /boot
store 1.8T 1.6T 167G 91% /store
node4:
tmpfs 32G 3.2G 29G 11% /run
/dev/sda3 105G 5.6G 94G 6% /
/dev/sda2 976M 195M 715M 22% /boot
/dev/md0 1.8T 1.6T 166G 91% /store
node1:
node2:
node3:
node4:
How long are we talking for recovery after restarting? No change after about 20 minutes.
node1-4
node1-4
Are you storing active ES data in /store ?
If so the systems are over the high-water mark and will not allocate or move shards because the disks are too full
You would need to add storage space if this is the case
store 1.8T 1.6T 167G 91% /storeRe: Cluster status Red after upgrade
Whats the high water mark threshold? Does it default to 90%?
The default watermark level is set to 85% of the disk that the elasticsearch data is located on.
https://support.nagios.com/kb/article.php?id=469
