NRPE v3.2.1 weird ssl error ....
Hi Nagios Team,
I have installed nrpe 3.2.1 on RHEL 7.3
Added Nagios server IPs to /etc/hosts.allow & /etc/xinetd.d/nrpe
But when nrpe client tried to communicate, throws a weird error.
PFA screen shot of the error.
Kindly assist.
Regards,
Vish.
Kindly assist.
Regards,
Vish.
benjaminsmith
Re: NRPE v3.2.1 weird ssl error ....
Hello Vish,
How did you install nrpe, did you follow the instructions below?
NRPE - How to install NRPE
Also, please upload or post the following file to the ticket. Thanks.
/etc/xinetd.d/nrpe
Hi Benjamin,
yes, nrpe was installed from https://support.nagios.com/kb/article.php?id=8
Below are the contents of /etc/xinetd.d/nrpe :
# default: off
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
disable = no
per_source = 25
socket_type = stream
port = 5666
wait = no
user = nagios
group = nagios
server = /usr/local/nagios/bin/nrpe
server_args = -c /usr/local/nagios/etc/nrpe.cfg --inetd
only_from = 127.0.0.1 x.x.x.x y.y.y.y z.z.z.z
log_on_success =
I recompiled nrpe manually using :
./configure --enable-command-args --disable-ssl
and ran command /usr/local/nagios/libexec/check_nrpe -H x.x.x.x -n
NRPE v3.2.1
So does that mean its a SSL librry related issue ?
Kindly assist.
Regards,
Vish.
NRPE v3.2.1
Kindly assist.
Regards,
Vish.
benjaminsmith
Hello Vish,
CHECK_NRPE: Error - Could Not Complete SSL Handshake
Most likely as your getting the "Could Not Complete SSL Handshake" error message. Follow the instructions in the article below to re-compile with SSL enabled.So does that mean its a SSL librry related issue ?
I followed the instructions from the link for installing nrpe , still get the below error :
Nothing seems to be working in this case.
Kindly assist as this is critical for us.
Also,Do you knowi if this is related to https://github.com/NagiosEnterprises/nrpe/issues/113
Nov 13 01:51:45 xinetd[6577]: xinetd Version 2.3.15 started with libwrap loadavg labeled-networking options compiled in.
Nov 13 01:51:45 xinetd[6577]: Started working: 1 available service
Nov 13 01:51:45 systemd: Reloading.
Nov 13 01:51:45 systemd: Binding to IPv6 address not available since kernel does not support IPv6.
Nov 13 01:52:00 xinetd[6774]: warning: can't get client address: Connection reset by peer
Nov 13 01:52:00 nrpe[6774]: Error: (!log_opts) Could not complete SSL handshake with : 5
yum list installed | grep openssl
openssl.x86_64 1:1.0.2k-19.0.1.el7 @OEL7.latest-patch
openssl-devel.x86_64 1:1.0.2k-19.0.1.el7 @OEL7.latest-patch
openssl-libs.x86_64 1:1.0.2k-19.0.1.el7 @OEL7.latest-patch
xmlsec1-openssl.x86_64 1.2.20-7.el7_4 @OEL7.latest-patch
ldd /usr/local/nagios/bin/nrpe
linux-vdso.so.1 => (0x00007ffc08e22000)
libssl.so.10 => /lib64/libssl.so.10 (0x00007f87f97b2000)
libcrypto.so.10 => /lib64/libcrypto.so.10 (0x00007f87f934f000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x00007f87f9135000)
libwrap.so.0 => /lib64/libwrap.so.0 (0x00007f87f8f2a000)
libc.so.6 => /lib64/libc.so.6 (0x00007f87f8b5c000)
libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007f87f890f000)
libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007f87f8626000)
libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007f87f8422000)
libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007f87f81ef000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f87f7feb000)
libz.so.1 => /lib64/libz.so.1 (0x00007f87f7dd5000)
/lib64/ld-linux-x86-64.so.2 (0x00007f87f9a24000)
libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007f87f7bc5000)
libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007f87f79c1000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x00007f87f77a8000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f87f758c000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f87f7365000)
libpcre.so.1 => /lib64/libpcre.so.1 (0x00007f87f7103000)
I even tried with client certs, but didnt work.
Log shows below :
/usr/local/nagios/libexec/check_nrpe -A
/usr/local/nagios/etc/ssl/ca_cert.pem -C
/usr/local/nagios/etc/ssl/client_cert.pem -K
/usr/local/nagios/etc/ssl/client_cert.key -H X.X.X.X
Nov 13 04:01:34 nrpe[1865]: SSL Certificate File: /usr/local/nagios/etc/ssl/client_certs/client_cert.pem
Nov 13 04:01:34 nrpe[1865]: SSL Private Key File: /usr/local/nagios/etc/ssl/client_certs/client_cert.key
Nov 13 04:01:34 nrpe[1865]: SSL CA Certificate File: /usr/local/nagios/etc/ssl/ca/ca_cert.pem
Nov 13 04:01:34 nrpe[1865]: SSL Cipher List: ALL:!MD5:@STRENGTH
Nov 13 04:01:34 nrpe[1865]: SSL Allow ADH: 0
Nov 13 04:01:34 nrpe[1865]: SSL Client Certs: Don't Ask
Nov 13 04:01:34 nrpe[1865]: SSL Log Options: 0xffffffff
Nov 13 04:01:34 nrpe[1865]: SSL Version: TLSv1 And Above
Nov 13 04:01:34 nrpe[1865]: Error: (nerrs = 0) Could not complete SSL handshake with : 5
benjaminsmith
Hello @vishfx,
It looks like you are having issues with the IP address on this system.
2. Is port 5666 open on the remote host? From the Nagios Server, run an nmap command on the remote host.
3. Try adding the local IPv6 ::1 address to the list of only_from addresses, for example:
1. Just to check, did you re-compile with SSL? If the following command, works, then SSL has not been enabled.Nov 13 01:51:45 systemd: Binding to IPv6 address not available since kernel does not support IPv6.
/usr/local/nagios/libexec/check_nrpe -H <remote host ip> -n
nmap nmap <ip of remote host> -p 5666<Code: Select all
vi /etc/xinetd.d/nrpe
only_from = 127.0.0.1 ::1 <Nagios XI server ip>
Am good with the fix for now.
This can be closed.
This can be closed.
benjaminsmith
Super! Thanks for the update. Closing.Am good with the fix for now.
This can be closed.
