Plugin to fetch the result of splunk query
Pratapa
Post by Pratapa »
We got a requirement as follows.
When we execute a Splunk query on the Splunk search header, Nagios should fetch the output of the splunk query. Nagios and Splunk are integrated. Is there a plugin which can fetch the result of the splunk query.
Regards,
Pratapa.
Re: Plugin to fetch the result of splunk query
We don't use Splunk in house, but a quick Google search returned this which may be what you are looking for
https://github.com/ecentria/splunk-search-nagios-check
