Hi Team,
Would like to check whether the size of performance graph can be changed based on axis.
For example, i want to increase one channel graph size to a bigger one as i could see the channel line very closer and not able to see the details separately for each channels..
Attached the screenshot of graph
Performance Graph vary axis length
Re: Performance Graph vary axis length
The graphs do not have a option to adjust the axis, however it does have the ability to turn off display of some of the metrics by clicking on the label under the graph which will resize the graph to allow the remaining (on) metrics to fix on the graph.
