about performance graph rta/rtmax/rtmin/pl ?!
xpertech
Post by xpertech »
when and where to see rta/rtmax/rtmin/pl on the performance graph, rather than only see rta/pl ?
and why I saw the old style performance graph, rather than new style ? where can change the style ?
Re: about performance graph rta/rtmax/rtmin/pl ?!
In the XI interface, you can select either the New style Graphs (Highchart) or the old style graphs.
Do to this, login to the GUI and go to the Admin > System Settings menu.
Click on the Theme & Display TAB and in that menu, you will see the setting foe changing the graph types.
The option is called the following.
Use Highcharts for Performance Graphs page and host/service detail pages (host/service popup graph always uses Highcharts)
Check the box and that will set all of the Graphs to Highchart style graphs.
The reason they were mixed before is that not all of the places for the graphs can use the old style graphs.
