Issue with scheduled report attachments
jvaira
Post by jvaira »
We are having an issue where scheduled reports are sent but regardless of the attachment type ( pdf, jpg etc. ) The attachments are always 200 bytes in size and do not contain any data.
benjaminsmith
Re: Issue with scheduled report attachments
Post by benjaminsmith »
Hello @jvaira,
Just to confirm, you are able to download PDF reports from the web interface. Is this correct?
Make sure you have the correct URL settings defined. Go to Admin > System Config > System Settings.
Please send us a copy of your system profile along with the blank PDF report. Thanks.
To send us your system profile.
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
jvaira
Post by jvaira »
Hello Ben,
The program URL was not entered correctly. Once I fixed that the reports began to send correctly.
Thank you
benjaminsmith
Glad to hear it's fixed.
I'll go ahead and close this post, but feel free to open another if you have any new questions.
