monitoring engine status no data?!
xpertech
Post by xpertech »
why sometimes the monitoring engine status display "no data"?!
benjaminsmith
Re: monitoring engine status no data?!
Post by benjaminsmith »
Hello @xpertech,
Looks like the dashlet is updating but it's not able to fetch any data. Have you made any changes to the server since this started happening? The data is retrieved from a php script running on a scheduled basis as a cron job.
1. Please post the output of the cron log
tail -n 25 /var/log/cron
2. Load the this page and tail the Apache log and post the output. Thanks.
tail -f /var/log/httpd/*error_log /var/log/httpd/*access_log
xpertech
Post by xpertech »
had PM attachments...
benjaminsmith
Hello @Xpertech
The logs contain the error below on the script that is parsing the status data for the server. This is a known issue that will be patched in the next maintenance release.
PHP Warning: simplexml_load_string(): in /usr/local/nagiosxi/html/includes/utils-systat.inc.php on line 17
If you'd like to fix this right away, see the forum post below. Also, be sure to make a backup copy of manage_services.sh before making any changes.
https://support.nagios.com/forum/viewto ... 16&t=55707
Let us know if you have any questions.
