Linux SNMP configuration throwing error
deek
Post by deek »
Hi ,
We have instrumented monitoring for appliances using Linux SNMP wizard.
we are getting error. "ERROR: Description/Type table : No response from remote host "172.xxx.xxx.xx".
Linux MiB has been installed on the target appliaces.
SNMP version is 2
Community string is : igprd
Ports 161 and 162 are open.
Sample Command: check_xi_service_snmp_linux_storage! -C igprd --v2c -m "^/$" -w 80 -c 95 -f
Deepan
deek
Re: Linux SNMP configuration throwing error
Post by deek »
You can close this case. since we found its because of change in community string.
deek wrote:You can close this case. since we found its because of change in community string.
Great!
Locking
