XI installation problem
lntinfo
Post by lntinfo »
i am trying installed below nagiosxi pkg on below mentioned system:
wget http://assets.nagios.com/downloads/nagi ... est.tar.gz
sytem:-Red Hat Enterprise Linux Server release 5.8 (Tikanga)
x86_64
i was following up with your latest docs.
tried to installed using ./fullinstall
the script that failed was ./0-yum
then i tried installing manually using ./0-yum
it was installed successfully it took 4 hours .
but now i am trying to install
./1-prereqs it throws below errror
Yum was not properly prepared - run previous script
is this because of, Manual Installation Problem: EPEL is down ?
problem from your end just confirm it ?
kindly help.
below is install.log
Nagios XI Installation Log
DATE: Tue Apr 24 13:33:02 CEST 2012
DISTRO INFO:
RedHatEnterpriseServer
5.6
x86_64
THIS IS A NEW INSTALL!
INSTALLING:
full=2011R2.3
major=2011
minor=R2.3
releasedate=2012-04-16
release=213
Configuring Yum...
An error has occurred:
Tunnel Connection Failed
See /var/log/up2date for more information
Your Red Hat Installation is not registered or does not have proper entitlements.
Please register or enable entitlements at rhn.redhat.com.
DATE: Wed Apr 25 07:27:08 CEST 2012
DISTRO INFO:
5.8
x86_64
INSTALLING:
full=2011R2.3
major=2011
minor=R2.3
release=213
Configuring Yum...
"install.log" 170L, 4441C
WARNING: This script will remove existing RPMs installed on this
         system, which may result in existing applications being
         removed!
Do you want to continue? [y/N]: RESP: y
64-bit system detected, modifying yum
Loaded plugins: rhnplugin, security
Setting up Remove Process
No Match for argument: *.i?86
Excluding Packages in global exclude list
Finished
No Packages marked for removal
Enabling RPMForge repo...
DATE: Wed Apr 25 08:40:29 CEST 2012
DISTRO INFO:
5.8
x86_64
INSTALLING:
full=2011R2.3
major=2011
minor=R2.3
release=213
Configuring Yum...
         removed!
Finished
curl: Remote file name has no length!
curl: try 'curl --help' for more information
error: File not found by glob:
rm: cannot remove `': No such file or directory
Finished
Skipping security plugin, no data
ERROR: rpmforge-release RPM was not installed - exiting.
DATE: Wed Apr 25 08:51:42 CEST 2012
DISTRO INFO:
5.8
x86_64
INSTALLING:
full=2011R2.3
major=2011
minor=R2.3
release=213
Configuring Yum...
         removed!
Finished
Finished
DATE: Wed Apr 25 09:16:31 CEST 2012
DISTRO INFO:
5.8
x86_64
INSTALLING:
full=2011R2.3
major=2011
minor=R2.3
release=213
Configuring Yum...
Could not retrieve mirrorlist http://apt.sw.be/redhat/el4/en/mirrors-rpmforge error was
[Errno 4] IOError: <urlopen error (110, 'Connection timed out')>
         removed!
Do you want to continue? [y/N]: RESP: Y
Exiting
Re: XI installation problem
Honestly, this looks like your machine cannot reach
This site is up and working properly.
Does this machine have direct connection to the internet?
lntinfo
Post by lntinfo »
using proxy
Make sure you have followed these steps
http://support.nagios.com/wiki/index.ph ... th_Proxies
lntinfo
Post by lntinfo »
yes.
no_proxy=localhost,127.0.0.0/8,10.0.0.0/8,172.16.0.0/12,192.168.0.0/16 # Hosts to exclude from proxying
i have not added above entry. is it necessary...
at persent i have hold my installation due to Manual Installation Problem: EPEL is down
once its up i will start my installation.
At the very lease adding no_proxy for localhost,127.0.0/0/8 would be a wise idea.
lntinfo
Post by lntinfo »
still facing issue after run ./fullinstall
INSTALLATION ERROR!
in your communications with Nagios XI technical support
DATE: Fri Apr 27 08:29:06 CEST 2012
below is the install.log file
DISTRO INFO:
5.8
x86_64
INSTALLING:
full=2011R2.3
major=2011
minor=R2.3
release=213
Configuring Yum...
removed!
Resolving Dependencies
--> Running transaction check
---> Package expat.i386 0:1.95.8-8.3.el5_5.3 set to be erased
---> Package glibc.i386 0:2.5-81.el5_8.2 set to be erased
Dependencies Resolved
Package Arch Version Repository Size
Removing:
expat i386 1.95.8-8.3.el5_5.3 installed 158 k
glibc i386 2.5-81.el5_8.2 installed 10 M
Transaction Summary
emove 2 Package(s)
Reinstall 0 Package(s)
Downgrade 0 Package(s)
Downloading Packages:
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
^M Erasing : expat 1/2
^M Erasing : glibc 2/2
Removed:
expat.i386 0:1.95.8-8.3.el5_5.3 glibc.i386 0:2.5-81.el5_8.2
Complete!
rpmforge-release RPM installed OK
Enabling EPEL repo...
plz help...as sooon as possible ....wating your reply
lntinfo
Post by lntinfo »
when ia m givng yum list commnand
yum list
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
No module named cElementTree
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.4.3 (#1, Dec 22 2011, 12:12:01)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-50)]
If you cannot solve this problem yourself, please go to
the yum faq at:
http://wiki.linux.duke.edu/YumFaq
lntinfo
Post by lntinfo »
i have came across below error although i have registered system with rhn
Configuring Yum...
DATE: Fri Apr 27 10:47:12 CEST 2012
DISTRO INFO:
5.8
x86_64
INSTALLING:
full=2011R2.4
major=2011
minor=R2.4
releasedate=2012-04-24
release=214
Configuring Yum...
agriffin
Post by agriffin »
How did you register your system with Red Hat? Was it with certificate-based authentication or some other non-standard method?
