Hello Team,
Recently we got one requirement .i.e, we need to send the CPU and memory utilization report in csv format for all network devices,we are monitoring around 200 devices .
is this possible to get report for 200 devices ? is there any option to create group ?
could you please suggest for this ?
Currently we are getting in csv format but that is not human readable could you please help to convert human readable format ?
Nagios graph
Re: Nagios graph
Service groups can be configured under Configure > Core Config Manager > Monitoring > Service Groups.
I'm a bit confused - do you want the data in csv format or another format?
How are you currently extracting data in csv format? Exporting CSV is a common request but there's no one way to do this. What method/commands are you using?
You may be interested in reviewing this tool which can export host and service information in csv format:
https://exchange.nagios.org/directory/U ... ol/details
manimurugesan
Re: Nagios graph
I want the data in csv format only .
I downloaded for only one host using below options .
graphs->graph explorer->scalable performance graph->download CSV
but it's not human readable .
Could you please confirm can we get graph utilization report in csv format for all network devices nearly we have 200 devices
Re: Nagios graph
CSV is not typically human readable. It's meant to be a simple, common format to export data from one system, and import into another system.
