My nagios xi install is reporting that there is an update available but when I go to the "check for updates" page it just shows the spinner and "Update in progress. Please wait. Update may take a few minutes." No data shows up in the update progress box. When I run the upgrade manually I get some errors
Reading configuration data...
Read main config file okay...
Error: Contact 'xi_default_contact' is not defined anywhere!
Error: Could not add contact 'xi_default_contact' to host (config file '/usr/local/nagios/etc/hosts/entsalesprinter.office.sonic.net.cfg', starting on line 16)
directives and data definitions. If you are upgrading from a previous
> Return Code: 1
But when I check the system profile it looks like I'm on the latest version 5.6.7 attached.
Is this expected behavior? Should I do anything or just ignore the update available notification?
Moderator's Note: The profile has been shared with the support team but has been removed from the public forum.
Upgrade available but not really
benjaminsmith
Re: Upgrade available but not really
Hello @kavan,
Thanks for sharing the system profile right away, that's very helpful. I noticed some crashed db tables, please log in as root to the terminal and run the following script.
It looks like you have an error in your configuration files. Go to the Configure > CCM > Hosts and search for entsalesprinter.office.sonic.net from the text box in the upper right. Click on the Alert Settings tab and change the contact to nagiosadmin or another contact from your list.
Next go to Tools > Config File Management, and go through the following steps.
1. Delete Files
3. Write Files
3. Verify Files .... if it doesn't pass, then correct the errors in the CCM and repeat steps 1-2
4. Restart Nagios Core
Once you have cleared the configuration error, run the following commands as root to upgrade.
/usr/local/nagiosxi/scripts/repair_databases.sh
1. Delete Files
3. Write Files
cd /tmp
rm -rf nagiosxi xi*.tar.gz
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
tar xzf xi-latest.tar.gz
cd nagiosxi
./upgrade
