Whoops!
Error: Could not read object configuration data!
Here are some things you should check in order to resolve this error:
Verify configuration options using the -v command-line option to check for errors.
Check the Nagios log file for messages relating to startup or status data errors.
Make sure you read the documentation on installing, configuring and running Nagios thoroughly before continuing. If all else fails, try sending a message to one of the mailing lists. More information can be found at http://www.nagios.org.
help me
apt-get remove nagios3 ---->
* errors in config!
[fail]
invoke-rc.d: initscript nagios3, action "start" failed.
dpkg: error processing nagios3-common (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of nagios3-cgi:
nagios3-cgi depends on nagios3-common (= 3.2.3-3); however:
Package nagios3-common is not configured yet.
dpkg: error processing nagios3-cgi (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of nagios3-core:
nagios3-core depends on nagios3-common (= 3.2.3-3); however:
dpkg: error processing nagios3-core (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
Errors were encountered while processing:
nagios3-common
nagios3-cgi
nagios3-core
E: Sub-process /usr/bin/dpkg returned an error code (1)
WOOPS
Re: WOOPS
What happens if you run the following command?
It seems something is wrong in your configuration files, so this command will hopefully narrow down the possible issues for us.
sudo nagios3 -v
