Hello folks;
My Nagios XI server (version 5.6.7) is slow to respond and sometimes we lose GUI access to it until we reboot (It's VM). and it keeps happening and i noticed that ndo2db process & mysqld process both are consuming high CPU especially ndo2db process.
Any idea what to do to fix that issue? currently we have to reboot the VM in order to bring it back to work but we can't sustain doing that.
Thank you in advance
Slow Nagios XI
Re: Slow Nagios XI
We have a couple of docs on performance tuning.
https://assets.nagios.com/downloads/nag ... uning.html
Those would be worth checking out. How many service checks are you performing, and what virtual hardware do you have assigned to your Nagios VM?
Re: Slow Nagios XI
The VM specs are :
16 GB RAM
8 vCPU
I have a little over 7000 services & about 950 servers configured to use Nagios
16 GB RAM
8 vCPU
Re: Slow Nagios XI
This document may be helpful, with so many service checks.
https://assets.nagios.com/downloads/nag ... giosXI.pdf
Also, with 7k service checks, and almost 1k hosts, you may need more memory and CPU. Can you post the results of these commands,
sar 1 10
sar -r 1 10As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
