I am using Nagios core to monitor our servers from past 14 months, but all of a sudden from yesterday I am continuously getting host check timed out after 30s for many servers and receiving host down alert and getting host up alerts within a minute. But when I logged in to server and checked, the server was never down. Below is the error message in nagios server :
nagios: job 3470 (pid=9458): read() returned error 11
nagios: wproc: Core Worker 23639: job 3470 (pid=9458) timed out. Killing it
nagios: wproc: CHECK job 3470 from worker Core Worker 23639 timed out after 30.01s
nagios: wproc: host=91d-prod-kfweb-n1; service=(null);
nagios: wproc: early_timeout=1; exited_ok=0; wait_status=0; error_code=62;
nagios: Warning: Check of host '91d-prod-kfweb-n1' timed out after 30.01 seconds
nagios: HOST ALERT: 91d-prod-kfweb-n1;DOWN;HARD;2;(Host check timed out after 30.01 seconds)
nagios: HOST NOTIFICATION: nagiosadmin;91d-prod-kfweb-n1;DOWN;notify-host-by-email;(Host check timed out after 30.01 seconds)
Someone kindly assist me on how to solve this.
Thanks.
Issue with Nagios core : False host time out alerts
Re: Issue with Nagios core : False host time out alerts
Are these host checks just doing ping checks?
If so, can you ping the IP for 91d-prod-kfweb-n1 when this happens from the Nagios server?
Can you share one of the host definitions?
Hi Scott,
For the past year, it was working fine. And yes, I can able to ping during the alert time.
I have attached host definition as requested. Moreover I can find the below error in the monitored server :
nrpe[6141]: Error: (!log_opts) Could not complete SSL handshake with x.x.x.x: 5.
Could not read request from client x.x.x.x, bailing out...
nrpe[31526]: INFO: SSL Socket Shutdown.
But no change was done in the Nagios server in recent times for me to receive the above error.
Kindly suggest.
Thanks.
Kindly suggest.
Thanks.
Host_definition.txt- PFA host definition
- (2.06 KiB) Downloaded 285 times
Can you attempt the following the next time this happens (replacing x.x.x.x with the IP of the server)
/usr/local/nagios/libexec/check_icmp -H x.x.x.x -w 3000.0,80% -c 5000.0,100% -p 5
This should be what Nagios should be attempting to execute.
Also, can we confirm there are not multiple nagios parent processes
ps -ef|grep nagios.cfgThis makes me wonder even more if something is happening on the network causing traffic to not route correctlyMoreover I can find the below error in the monitored server :
Sure next time I'll run the nagios check_icmp command. Below is the output of ps -ef | grep nagios.cfg
So there are 2 parent process .
nagios 18448 1 0 Oct19 ? 00:01:50 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 18454 18448 0 Oct19 ? 00:00:14 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
What can I do ?
What can I do ?
That's actually just 1 parent and one child, so that is normal. At this point we need to see what the server sees by running the command when it is reporting the timeoutsitssameer wrote:So there are 2 parent process .
What can I do ?
