Hi
how to monitor the GPU for a given nvidia device using nvidia-smi. I see there are plugins for this.
is there a better way to monitor the GPU metrics
Deepan
Nvidia Nagios monitoring Query
Re: Nvidia Nagios monitoring Query
I found two 3rd party plugins on the Nagios Exchange. You can try them out to see if they are going to do the job for you.
https://exchange.nagios.org/index.php?o ... ord=nvidia
Once you determine that your checks work from the command line, you could create a new command and a service, by following the steps, outlined in the document below:
