Configure Email Alerts using an internal Nagios Xi
Hello Support,
I would need to use something within Nagios Xi such as internal SMTP or setup something like POSTFix in order to send out alerts to our company emails, can't use any third party SMTP or our company SMTP, so only option is to use something internally in Nagios Xi to send out all the alerts to our company email addresses. Please, help.
Re: Configure Email Alerts using an internal Nagios Xi
Ok. instead of SMTP option, I have used sendfrom Outbound Mail Settings Option & using one of our internal email address.
Please, confirm if that will work well to send out the email alerts as well? instead of using any SMTP server. What type of email system does Send from uses by the way, just curious to know.
benjaminsmith
Hello @mamir,
It will use the default MTA (Mail Transfer Agent) provided by the Linux distribution. This is typically sendmail or postfix.What type of email system does Send from uses by the way, just curious to know.
Ok. Is this postfix feature built in Nagios Xi already when I use Send From Email to send out the alerts?
benjaminsmith
Yes, it installed by CentOS. Send a test mail and check the mail logs if you don't receive the message.
/var/log/maillog
Ok understood. Ok a different note: I need to limit the notification alerts. I want to check a service or a host every minute. If either a host or a service is down, like to be notified immediately, but only one notification alert come in for the next 600 minutes & if it is recovered before 600 minutes, i should just get one recovery email notification. Please, assist, where exactly for a host or services, i can set it up. I'm getting multiple notifications for the same host or services in one minute. Therefore, i just want to limit & get only one right away & then 600 minutes should be the wait time for the second notification if its still down. Please, help me.
benjaminsmith
Hello @mamir,
You can accomplish this by setting the notification interval to 600.
To set this in Nagios XI, go to Configure >Monitoring > Hosts or Services > Alert Settings.notification_interval: This directive is used to define the number of "time units" to wait before re-notifying a contact that this host is still down or unreachable. Unless you've changed the interval_length directive from the default value of 60, this number will mean minutes. If you set this value to 0, Nagios will not re-notify contacts about problems for this host - only one problem notification will be sent out.
Cap1
I have setup these settings, I stopped one service just for testing & host was still up. But I recieved 2 service down alerts & 2 host UP alerts.
Please, check my settings, what I'm missing here. Because I should have only recieved one service down alert, the second should only be recieved after every 600 minutes. Also why a HOST alert, is that expected, because for HOST if should only send it when a HOST is down or recovered correct?
This seems to be duplicate alerts one HOST UP & other email recieve at same time which is expected 1 service down alert.
benjaminsmith
Hello @mamir,
If you're receiving duplicate notifications, check the contacts associated with the servers to make sure you do not have multiple contacts with the same email. Otherwise, it's possible that you have multiple nagios process running, run the following commands.
Are you certain the host was never down? Can you verify this in the state history or nagios logs.Also why a HOST alert, is that expected, because for HOST if should only send it when a HOST is down or recovered correct?
systemctl stop nagios
pkill -9 -u nagios
systemctl start nagios
Ok. There might be something off, so i reinstall Nagios Xi from scratch & now able to recieve just one alert. Thanks for your help.
so basically, when I add a new host, there is no modification needed correct, just notification interval, i can change to 600 minutes which will mean after my first down alert, it will not send another notification only after each 600 pass by correct.
We can close this loop. Thanks for your support again.
