Edit Nagios Core Web GUI Host URL to open in new tab.
humblestudent
Hello Community,
I am trying to customize the Nagios Core Web GUI to have the hosts' URL open in a new tab on a web browser. Particularly, I am trying to configure the https://name_of_nagios_host/nagios/cgi-bin/status.cgi?hostgroup=all&style=overview
I am trying to find this style=overview, but it looks like it is some how generating the list of hosts based off the cgi. I was wondering if there was a way to configure it to add target="_blank" to each a herf for host names.
Re: Edit Nagios Core Web GUI Host URL to open in new tab.
The only way I can think to do this would be with JS, you would have to add the following to the botton of the /nagios/js/nag_funcs.js script
On a source install this file would be
/usr/local/nagios/share/js/nag_funcs.jsCode: Select all
$(document).ready(function() {
$( "a[href*='status.cgi?host']" ).attr( "target", "_blank" );
humblestudent
Thank you for your prompt reply @scottwilkersonscottwilkerson wrote:The only way I can think to do this would be with JS, you would have to add the following to the botton of the /nagios/js/nag_funcs.js script
On a source install this file would beCode: Select all
$(document).ready(function() { $( "a[href*='status.cgi?host']" ).attr( "target", "_blank" ); });
Unfortunately I do not see that file.
I am running Nagios Core 4.2.4
and here is what is listed in my js directory:
$ pwd
$ ls
histogram-events.js histogram-graph.js jquery-1.7.1.min.js map-directive.js map.js nagios-time.js trends-graph.js
histogram-form.js histogram.js jsonquery.js map-form.js nagios-decorations.js trends-form.js trends.jsAny additional tips or help would greatly be appreciated.
What version of nagios are you using? The file I showed is in the latest
Technically you could add a few new lines and add it to jquery-1.7.1.min.js
humblestudent
I am running Nagios Core Version 4.2.4scottwilkerson wrote:Technically you could add a few new lines and add it to jquery-1.7.1.min.js
Your tip looks like it may have worked.
I added your code snippet to jquery-1.7.1.min.js and restarted the nagios and httpd services, and it looks like that was able to do the trick.
/*! jQuery v1.7.1 jquery.com | jquery.org/license */
You would have to play with this to get what you want
Example: all URL's that contain host=
$( "a[href*='host=']" ).attr( "target", "_blank" );
humblestudent
Think I answered my follow up question. when clicking on hosts under the Hosts and Services tab, they open to the following URL:humblestudent wrote:I am running Nagios Core Version 4.2.4scottwilkerson wrote:Technically you could add a few new lines and add it to jquery-1.7.1.min.js
This seems to work when clicking on hosts under "Host Groups" and "Service Groups" but it doesn't seem to work when clicking on Hosts under "Hosts" (https://host_name/nagios/cgi-bin/status.cgi?hostgroup=all&style=hostdetail) and "Services" (https://host_name/nagios/cgi-bin/status.cgi?host=all) Any other thoughts?Code: Select all
/*! jQuery v1.7.1 jquery.com | jquery.org/license */ $(document).ready(function() { $( "a[href*='status.cgi?host']" ).attr( "target", "_blank" ); });
https://name_of_nagios_server/nagios/cgi-bin/extinfo.cgi?type=1&host=server_or_service_nameCode: Select all
$( "a[href*='extinfo.cgi?type']" ).attr( "target", "_blank" );
humblestudent
scottwilkerson post resolved this issue.
Great!humblestudent wrote:scottwilkerson post resolved this issue.
Locking thread
