EPEL Repo issues, still?
GaWd
Post by GaWd »
I see the stickied thread has disappeared, but I still cannot install nagiosxi on my test server:
Nagios XI Full Installer
This script will do a complete install of Nagios XI by executing all necessary sub-scripts.
IMPORTANT: This script should only be used on a 'clean' install of CentOS or RedHat. Do NOT use this on a system that has
been tasked with other purposes or has an existing install of Nagios Core. To create such a clean install you should have
selected ONLY the 'Base' package in the OS installer.
Do you want to continue? [Y/n] y
Proceeding with installation...
Checking MySQL credentials...
MySQL not yet installed - that's okay.
Running './0-yum'...
Configuring Yum...
rpmforge-release RPM installed OK
Enabling EPEL repo...
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-yum'
Re: EPEL Repo issues, still?
You will need to re-download the latest tarball for our version 2011R2.4 which has fixes for the repo problem built-in.
GaWd
Post by GaWd »
Ah. WIll do.
THanks!
