Hi
I am tried to modify one argument in multiple services checks using the bulk modification tool. When using the tool to modify 1 argument, the tools seem to modify the other arguments even if don't put a value in the arguments in the bulk modification tool. It seems to consistently modify all arguments regardless.
how can I modify just 1 argument?
Bulk Modification - Modifying Arguments
Re: Bulk Modification - Modifying Arguments
Unfortunately, you cannot modify only one argument via the bulk mod tool. If you left the rest of the fields empty, nagios would "think" that you wanted to wipe them out (not use any arguments).
You could copy/paste the "original" arguments in the rest of the fields (the ones that you don't want to change), and modify only the one argument you need to.
Note: This won't be useful in all cases. For example, if you had a command, used in several services that you wanted to modify only one argument on, but the rest of the arguments were all different, you couldn't do it. Let's say, you have two dummy services, "dummy1" and "dummy2".
You could use the bulk mod tool to change the first argument ("0"), to let's say "1", so that the services would return a "WARNING". If you left the second field blank, the bulk mod tool would remove "apple" and "orange". You could enter something in the second field, e.g. "pear", but then this would affect both services...
Obviously, this is not ideal and cannot be used in all cases. Hope this makes sense. Thanks!
host_name myhost
service_description dummy1
check_command check_dummy!0!"apple"
host_name myhost
check_command check_dummy!0!"orange"
}Code: Select all
host_name myhost
check_command check_dummy!1!"pear"
host_name myhost
}Be sure to check out our Knowledgebase for helpful articles and solutions!
Yes, Make sense. Unfortunately in my case I wanted to modify only 1 ARG
thanks you can close the ticket
