Hi
I have a service check that has 3 arguments, one of them is unique in different for every service check, the other 2 are the same across the board.
So what I want is I want to use a service template to control the other 2 arguments. but inheritance doesn't seem to work for the 2 arguments
can you help please?
Inherit Arguments in a service check
Re: Inherit Arguments in a service check
Unfortunately this will not work as the template inheritance works on a per object definition line and the command and arguments are all part of the check_command line in the object definition.
So, even though they appear separate in the CCM to make it easier to view, the underlying Nagios Core engine sees them as a single item.
thanks.
you can close the ticket
Locking threadbosecorp wrote:thanks.
