Getting ./0-repos error while installing the application in rhel 7 vm.
according to install.log, it is wrongly deteting the VM disto as centos 5.5 and throughing error : "CentOS / RHEL 5 is no longer supported due to end of life."
I am new to Nagios , pls help !
Note: Logs and screenshot are attached.
unable to install Nagios XI on my rhel 7 vm
Re: unable to install Nagios XI on my rhel 7 vm
You are getting a bunch of Permission denied errors
This may be because you are installing from a directory that has noexec set. Some orgs do not allow execution of scripts from /tmp
