get more details about an error
Hoygen83
Post by Hoygen83 »
I would like to understand what I'm doing wrong.
I have a windows host that is signaled as down.
I followed this guide https://assets.nagios.com/downloads/nag ... ndows.html
the check that's having problems is this one:
CPU Usage
This service has 1 comment associated with it This service is flapping between states
UNKNOWN 10-29-2019 16:27:12 0d 0h 0m 54s 1/5 Incorrect credentials given.
What credentials are given, from who and where?
benjaminsmith
Re: get more details about an error
Post by benjaminsmith »
Did you install and setup the NCPA agent on the Windows system. Do you have the correct password set in the check command in Nagios. Log into the terminal and try running the plugin directly from the shell. Post any errors to the thread. Thanks.
cd /usr/local/nagios/libexec
check_ncpa.py -H 1<ipaddreess> -t 'password' -P 5693 -M cpu/percent -w 20 -c 40 -q 'aggregate=avg'
Hoygen83
Post by Hoygen83 »
benjaminsmith wrote:Hello,
I'm sure I'm missing something.
I installed the ncpa agent version 2.2.0 on the windows machine.
During the installation, since I'm still testing the product I set up a token, I did not set up a bind ip because I don't know what it is, then I clicked next and next and next.
if I give this command:
check_ncpa.py -H 1<10.100.0.8> -t 'password' -P 5693 -M cpu/percent -w 20 -c 40 -q 'aggregate=avg'
I get
-bash: 10.100.0.8: No such file or directory
Now I have even more questions: what is the password and where (in what file on the host and on the nagios server) I define it?
Pardon my colleagues typo error. You would run
./check_ncpa.py -H 10.100.0.8 -t 'password' -P 5693 -M cpu/percent -w 20 -c 40 -q 'aggregate=avg'
Hoygen83
Post by Hoygen83 »
thank you for clearing it.
if I give
what password should i insert? the one of a local administrator in the windows machine?
Anyway I repeated the procedure following this guide:
and now I have NO credentials error on nagios.
so as I suspected I was doing something wrong.
Hoygen83 wrote:what password should i insert? the one of a local administrator in the windows machine?
this is the token you setup when installing NCPA
