I use "passive check" and enable check_freshness, freshness_threshold.
data expired send "PROBLEM Alert(expire)" notification correctly.
But how to configure send "RECOVERY" Notification
, while "passive check" continuary STATUS 0.
Does anyone know a good way?
Regards
Freshness chesk RECOVERY Notification.
Re: Freshness chesk RECOVERY Notification.
If the passive sends a 0 (OK) it will trigger recovery automatically
