Database Maintenance RED Status Need Help !!!!
rambertnala
I need help.
I am not able to get a solution for 2 susyem status errors
Database maintenance
Event Manager
Event Manager
Re: Database Maintenance RED Status Need Help !!!!
Can you attach the following 2 files
/usr/local/nagiosxi/var/eventman.log
/usr/local/nagiosxi/var/dbmaint.log-
rambertnala
Hi allscottwilkerson wrote:Can you attach the following 2 filesCode: Select all
/usr/local/nagiosxi/var/eventman.log /usr/local/nagiosxi/var/dbmaint.log
I have restored backup successfully. Now i am repairing databases
https://support.nagios.com/forum/viewto ... =6&t=56249
I will check if it has been resolved with that.
If not i will attach them
rambertnala
These are steps i have done:
Restored Backup 21 October ( How can I restore a snapshot i have downloaded from 29 October????)
Repaired databases
Still RED dot System Status Database Maintenance
Stop CROND
Deleted dbmaint.lock & dbmaint.log
Start CROND
Waiting minutes
OUPUT dbmaint.log
CREATING: /usr/local/nagiosxi/var/dbmaint.lock
CLEANING ndoutils TABLE 'commenthistory'...
SQL: DELETE FROM nagios_commenthistory WHERE entry_time < FROM_UNIXTIME(1540973701)
CLEANING ndoutils TABLE 'processevents'...
SQL: DELETE FROM nagios_processevents WHERE event_time < FROM_UNIXTIME(1540973701)
CLEANING ndoutils TABLE 'externalcommands'...
SQL: DELETE FROM nagios_externalcommands WHERE entry_time < FROM_UNIXTIME(1571904901)
CLEANING ndoutils TABLE 'logentries'...
SQL: DELETE FROM nagios_logentries WHERE logentry_time < FROM_UNIXTIME(1564733701)
CLEANING ndoutils TABLE 'notifications'...
SQL: DELETE FROM nagios_notifications WHERE start_time < FROM_UNIXTIME(1564733701)
CLEANING ndoutils TABLE 'contactnotifications'...
SQL: DELETE FROM nagios_contactnotifications WHERE start_time < FROM_UNIXTIME(1564733701)
CLEANING ndoutils TABLE 'contactnotificationmethods'...
SQL: DELETE FROM nagios_contactnotificationmethods WHERE start_time < FROM_UNIXTIME(1564733701)
CLEANING ndoutils TABLE 'statehistory'...
SQL: DELETE FROM nagios_statehistory WHERE state_time < FROM_UNIXTIME(1556957701)
What can I do???
Repaired databases
Stop CROND
Start CROND
Waiting minutes
OUPUT dbmaint.log
What can I do???
rambertnala
OOooohhhhhhhhhhhh
Surprise Database Maintenance & Event Manager GREEN dot
Only need to know how to restore a snapshot.
I have copied file to /usr/local/nagiosxi/nom/checkpoints/nagioscore/archives/
But when i try to restore it says file doesn't exist. Is possible it was cause I dont have .txt file???
To restore snapshots you would need to copy everything under
They should already be there if you restored a backup...
/usr/local/nagiosxi/nom/checkpoints/-
rambertnala
Hi friend.
No it was not there. It was created 29 October and i restored a backup from 21 October.
Local Backup is created Every Monday at 4:00 AM
Backup from 28 October failed, and began problems. So i had to restore a backup from 21 October.
All changes made until 29 October have been lost...
So is possible to restore a snapshot from 29 October ????
Thanks and regards.
Thanks and regards.
Oh, you would have to copy everything from
to the new server
This is only the configurations however, it will not contain any plugins or users you may have added in that timeframe
/usr/local/nagiosxi/nom/checkpoints/This is only the configurations however, it will not contain any plugins or users you may have added in that timeframe
rambertnala
I have copied snapshot file from 29 October in
and
/usr/local/nagiosxi/nom/checkpoints/archives/
I try to restore but i get error
File does not exist
Regards
and
File does not exist
Regards
Under
there are 2 directories nagiosxi & nagioscore
you need to contents of both of these directories moved to the new server with every file in the exact same location as they were on the original server
then for good measure you should run the following to make sure run the following to make sure you didn't change the permissions when you moved the files
Once you have done all of that, then try the restore
ll /usr/local/nagiosxi/nom/checkpoints/Code: Select all
drwxr-xr-x 4 nagios nagios 4096 Oct 30 16:49 nagioscore
drwxr-xr-x 3 nagios nagios 4096 Oct 30 16:49 nagiosxithen for good measure you should run the following to make sure run the following to make sure you didn't change the permissions when you moved the files
chown nagios:nagios -R /usr/local/nagiosxi/nom/checkpoints
