N Core on RaspberryPi, email not generated . . .
Just installed latest N Core, also with sendmail installed. Initially, trying to monitor port 8080 on a subject Windows machine. The web interface can see and know when the service on that port drops. But no Email alert. I can run a command line script and receive an email out of the Pi. So I know that sendmail is correct. Worked with the commands.cfg without good results. What can I provide that would help diagnose the problem?
Re: N Core on RaspberryPi, email not generated . . .
Please let us know the exact host/service in question AND send us the resulting /tmp/NAGIOSFILES.zip file from this command:
Generally would be this:
But you'll need to tailor to your system.
zip -r /tmp/NAGIOSFILES.zip /path/to/your/nagios/etc/directoryCode: Select all
zip -r /tmp/NAGIOSFILES.zip /usr/local/nagios/etc
