CHECK_NRPE: Receive header underflow - only 0 bytes received
I am using github issue to record my issue.
Please see details at https://github.com/NagiosEnterprises/nrpe/issues/218
let me know if you need more info.
benjaminsmith
Re: CHECK_NRPE: Receive header underflow - only 0 bytes rece
Hello @nagmoto,
I believe you are hitting this issue and need to compile NRPE with enable command arguments.
https://github.com/NagiosEnterprises/nrpe/issues/92
See: NRPE - How To Install NRPE v3 From Source
cd /tmp/nrpe-nrpe-3.2.1/
./configure --enable-command-args
make all
I am using stock nrpe-3.2.1-8 rpm for centos 7.
the src.rpm was downloaded to see if EPEL missed the " --enable-command-args" ?
But it does have this argument in configure script.
<snipped from nagios.spec>
%build
CFLAGS="$RPM_OPT_FLAGS" CXXFLAGS="$RPM_OPT_FLAGS" LDFLAGS="%{?__global_ldflags}" \
%configure \
--with-init-dir=%{_initrddir} \
--with-nrpe-port=%{nsport} \
--with-nrpe-user=nrpe \
--with-nrpe-group=nrpe \
--with-piddir=/var/run/nrpe \
--bindir=%{_sbindir} \
--libdir=/doesnt/matter/ \
--libexecdir=%{_libdir}/nagios/plugins \
--datadir=%{_datadir}/nagios \
--sysconfdir=%{_sysconfdir}/nagios \
--localstatedir=%{_localstatedir}/run/ \
<snipped>
Also following showing check_nrpe is able to accept arguments from check_time test.
%build
%configure \
<snipped>
[pi@nagios4 src]$ ./check_nrpe -H localhost -2 -4 -c check_logfiles_4A -a "/var/log/nagios/nagios.log" "nagios-log" ".*] Error:.*" ".*NOERROR.*"
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
[pi@nagios4 src]$ check_nrpe -H localhost -c check_time -a localhost 1 2
OK - timedrift=0 seconds | timedrift=0s;1;2
[pi@nagios4 src]$
benjaminsmith
Hello @nagmoto,
Hope you had a great weekend. Make sure you have the configuration file set to receive arguments.
If your not sure, you can post the nrpe.cfg file from the remote host to the thread.
dont_blame_nrpe=1
Hi
Please see the checking of "don't blame" setting at https://github.com/NagiosEnterprises/nrpe/issues/218
I also compile nrpe and check_nrpe from the instruction, to replace binaries from nrpe centos packages. Result is the same.
"check_nrpe -H localhost -c check_time -a localhost 1 2" command is working as expected.
benjaminsmith
Hello @nagmoto
We did a few different tests and the results are that we can run your version directly from the command line but there's an issue with escaping your regex expression. For example, the following version work:
One option is to hard code the matching argument, nagios-log" ".*] Error:.*, in the command definition or possible modify the expression as we had difficulty escaping the [ bracket.
./check_nrpe -H 192.168.18.151 -c check_logfiles_4A -a /usr/local/nagios/var/nagios.log nagios-log .*[^]] Error.* .*NOERROR.*
Thanks for the great pointer for R.E. argument passing issue. I am able to use the walk around to do the logfile checking.
Can this issue be classified as bug and fix it in future NRPE release ?
benjaminsmith
Hello @nagmoto,
Happy to hear you got the logfile check working. We did q number of tests until we found the particular regex character that was causing the error.
As far as if this is a bug or not with NRPE, would you be able update the GitHib issue you posted for a developer to review?
Thanks for you reply again. Please close this ticket.
I will update github issue with more detail for developer to review.
benjaminsmith
Hello @nagmoto,
I'll mark this as resolved. Please feel free to open anther post if you have any new questions.
Much appreciated.I will update github issue with more detail for developer to review
