Modern Dark Theme- IE
esostarich
Post by esostarich »
In Internet Explorer, the Modern Dark Theme does not seem to translate to all dashlets.
For example, when the Modern Dark Theme is selected, only the column headers in the Host Status dashlet reflect this theme. The rest of the dashlet table does not, making the columns (Duration, Attempt, Last Check, and Status Information) difficult to read.
This is not the case when the same dashlet is accessed through Firefox.
Is there a way around this in IE?
cdienger
Re: Modern Dark Theme- IE
Post by cdienger »
Thanks for pointing this out. I'm able to reproduce and will file a bug.
