i am looking for a Plugin or wizard to monitor specific files on a server (*xml), our application generates multiple xml files to multiple locations. I need Nagios to do find on xml files on the whole server and if the number is above threshold i need to be alerted.
Folder watch Wizard
benjaminsmith
Re: Folder watch Wizard
Hello @ISSB_MAOST,
I did some research on the Nagios Exchange, and there's a simple pluigin called check_files_count. For arguments, you can set the path and file type.
check_files_count
https://github.com/DennyZhang/monitorin ... file_count
If you need assistance on installing a plugin in Nagios XI, check the guide below. Let us know if you get it setup and working.
Managing Plugins In Nagios XI
check_files_count
