Network Status Map
fsodah
Network Status Map
Post by fsodah »
Since my env. is huge ... how can i adjust Network Status Map ... in order to have it in proper view
fsodah
Re: Network Status Map
Post by fsodah »
any updates
Themes in XI don't apply to Nagios Core. So, when you use the dark theme and the "legacy" Network Status Map, the map is pretty bad. You cannot see the lines, cannot scale it (unless you log into the Nagios Core interface). Why don't you use the "new" Network Status Map instead?
Home > Maps > Network Status Map
It is a lot better. You can scroll with the mouse to zoom in and out, change root nodes, etc.
fsodah
Post by fsodah »
Done ... i switched to network status maps ... done close the ticket please
