Is there a way to produce a report that would have, for all systems, by system each alert that is configured for that system? Mgmt wants something like that....
Mitch
CSV report of all configured alerts?
GhostRider2110
Re: CSV report of all configured alerts?
You can get it in JSON through the API, Help -> Objects Reference
objects/host
objects/service
You could also pull it out of the database with something like this:
objects/host
objects/service
echo "select name1 as host, name2 as service from nagios_objects where is_active=1 and objecttype_id IN (1,2) order by host,service;"|mysql -pnagiosxi nagios-
GhostRider2110
Thanks Scott, I will see what I can do with that...
Mitch
Mitch
Sounds good,GhostRider2110 wrote:Thanks Scott, I will see what I can do with that...
Mitch
Locking thread
