Since updating to Log Server version 2.1.1 I cannot create new Alerts. The System says the alert already exists no matter what name I attempt to use.
See attached screen shot.
Thank you.
Cannot create new Log Server Alert
Re: Cannot create new Log Server Alert
This is a bug in 2.1.1. It will be fixed in 2.1.2 which is currently expected next week.
Ok, thank you.
Glad to help. I'll ping our dev team to see if we can provide a fix before then.
The part that needs fixing is encrypted so I can't provide it. You will need to wait for the update to get the fix.
This can be locked, we're doing the 2.1.2 update today and I've already confirmed it fixes the issue on my Log Server test box.
Thanks for the update!
