Monitoring Atlassian products
Kukkurloom
Post by Kukkurloom »
Hello fellow Nagios people!
I am currently building services on my Nagios Core 4.4.3 and since we would like to monitor Atlassian products (Jira, Bitbucket, Confluence and Bamboo) is here anyone out here who has some experience with that? Right now Im building check_http service for our Jira server, but it returns with an error:
connect to address [IP] and port 80: No route to host
And when I change the host address to a different one it gives me:
140467010549680:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:s23_clnt.c:794:
Right now my define service is like that:
        service_description             Jira_http
        check_command                   check_http_url!http://address1.address2/jira -s  --expect=200 -p 8080
        host_name                       Jira
        notification_interval           0
        notifications_enabled           1
        flap_detection_enabled          1
        register                        1
And the commands.cfg file looks like this:
        command_name    check_http_url
        command_line    $USER1$/check_http -H $HOSTADDRESS$ -U $ARG1$
Also tried the follow command in the end and it gave me an error like that:
connect to address [IP] and port 443: No route to host
HTTP CRITICAL - Unable to open TCP socket
[root@nagios libexec]# ./check_http -I [IP] -u https://address/Dashboard.jspa -S -f follow
Also tried it a little different, where it gives me some information, but still displays HTTP WARNING and on Nagios webpage its just empty:
root@nagios libexec]# ./check_http -H [IP] -p 8080 -f follow
HTTP WARNING: HTTP/1.1 404 - 92 bytes in 0,002 second response time |time=0,001526s;;;0,000000 size=92B;;;0
Side note: If I changed check_command line on define service by adding $ARG1$ in the end it just show that states are flapping on nagios webpage.
Thank you all for your help and advice,
All the best,
Kukkurloom.
Re: Monitoring Atlassian products
One thing I noted is that your command has the wrong case -U should be -u and -u is the URI, not the full URL
change to
        command_line    $USER1$/check_http -H $HOSTADDRESS$ -u $ARG1$
What do you get with this
./check_http -H [IP] -p 8080 -f follow -u "/jira"
Kukkurloom
scottwilkerson wrote:One thing I noted is that your command has the wrong case -U should be -u and -u is the URI, not the full URL
change to
Thank you Scott!
It helped me a lot! I got one more little question, how should I write down host addresses, if I write IP on the host address line it will give me: connect to address [IP] and port 8080: No route to host and if I write the whole address copied from the URL bar it will say the same, should I find some specific URL for this to work? :)
Edit 2:
Did not notice the URI part, got it working! Thanks so much again for the help! Can close that issue. :)
Best regards,
Kukkurloom.
Kukkurloom wrote:Edit 2:
Great!
Locking thread
