Service not removed even after removing the host from config
Pratapa
Post by Pratapa »
We faced a problem today.
There is a service called "Total - Processes" on one of the servers say host4. We need to remove this service from monitoring.
I have removed the hostname(host4) from the service definition in the service configuration file. Restarted Nagios service.
But service is not getting removed from monitoring. It is still showing. What could be the problem?
use linux-service-template,Total-Process-Template
host_name host1,host2,host3,host4
contact_groups linux-os-admins
Regards,
Pratapa.
Re: Service not removed even after removing the host from co
can you search for the service name in all of the configuration directory, such as
grep "Total - Processes" -R /usr/local/nagios/etc
Also, it looks from you example that host4 is still in this config
Pratapa wrote:define service {
