Hi I had an issue in the plugin that was fixed so now when I try to run a check on the Nagios services for the host it keeps showing up with the message(s):
Dell EMC Server TrapsPassive Only Check Unknown 32m 17s 2/5 2019-11-12 10:33:41 Error:WSMAN: No response from remote host
Dell EMC Server Voltage Probe Status Unknown 30m 30s 2/3 2019-11-12 10:33:41 Error:WSMAN: No response from remote host
Dell EMC Server Intrusion Status Unknown 43m 28s 2/3 2019-11-12 11:01:21 (No output returned from plugin)
When I go to "Forced immediate check for host and all services" from the host itself, it doesn't do anything.
However, when I go directly to the service, i.e. (Dell EMC Server Traps), and run a Force an immediate check
works and goes green again.
How do I get it so nagios runs a force immediate check on all the boxes without having to go into each one individually on my part since we have thousands of these?
Dell EMC OpenManage Plug-In Running Check Fails
Re: Dell EMC OpenManage Plug-In Running Check Fails
Newer versions of XI have Home > Incident Management > Mass Immediate Check, that can be used to force and immediate check on large groups. Does you have this option?
Failing that, you could try scripting something with an external command:
https://assets.nagios.com/downloads/nag ... and_id=128
Ah that's perfect. Didn't realize this existed. Thanks!
Glad to hear the new feature is useful
