Downtime Email Notifications editable?
cmueller
Post by cmueller »
Good morning,
is there a way to modify the textof the downtime start/end notification emails?
Best regards
Christophs
Re: Downtime Email Notifications editable?
If you are using the default XI notification commands, you can modify then and the following PDF document has instructions to do that.
https://assets.nagios.com/downloads/nag ... iables.pdf
But, this will modify all of the notifications and there is not a way to just modify Downtime notifications.
They are just standard notifications like all of the others.
The only option is to write a script that interprets all of the notifications and when it see a downtime, do something different and then replace that new command with the existing notification commands.
