Network Interface Bandwidth not polling the correct value
mejokj
Post by mejokj »
Hi Team,
One of our network device interface bandwidth is not polling the correct value. There was some interface bandwidth degradation happened yesterday but this was not reflected in Nagios Xi performance graph. It was showed a constant value.
Attached the screenshot for reference. Please suggest.
For example, the network interface bandwidth was reduced below 4 Mb/s between 6:15 PM to 6:20 PM. but it was showed above 6 value.
Re: Network Interface Bandwidth not polling the correct valu
Can you run the following commands as root and post the the /tmp/mrtg.txt file to the ticket?
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg -debug=cfg,base,log &> /tmp/mrtg.txt
LANG=C LC_ALL=C /usr/bin/mrtg &>> /tmp/mrtg.txt
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok --user=nagios --group=nagios &>> /tmp/mrtg.txt
{ time LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg 2>1 ; } 2>> /tmp/mrtg.txt
What is the IP address of the device with the issue?
I will need that to go through the data in the mrtg.txt file so make sure it is included.
inshad
Post by inshad »
kindly find the attached file
The files you uploaded are settings for the SNMP daemons and the MIB files which we do not need so can you run the following and post the MRTG information?
