Report for scheduled downtime.
I want to generate the report where I can see who generate the scheduled downtime, how many scheduled downtime on one server or given number of servers.
Re: Report for scheduled downtime.
There is not a report in Nagios XI that you can use to get the details on who and when scheduled downtime was done.
The best you can do it to run the Event Log report and download it as a CSV file and search through that to get the data.
One thing, you will have to enable the log_external_commands option before that data is added to the Event Log.
Edit the /usr/local/nagios/etc/nagios.cfg file and change this from
to
Save the file and restart nagios.
log_external_commands=0Code: Select all
log_external_commands=1Be sure to check out our Knowledgebase for helpful articles and solutions!
ok, please improve reporting function in Nagios xi. However, what log_external_commands will do. Is ti safe to turn on this option?
If the system if not processing a log of external commands, then enabling the logs should not affect the system very much.
I'll put in a feature request asking the a detailed Scheduled Downtime report.
