Nagios check interval every 5min for 3000 every 10 min 25000
grayloglearn
Post by grayloglearn »
Hi Team,
We have 1700 hosts, with Nagios XI 5.6 version.
We have 28000 services out of this 25000 services checks will happen every10min.
3000 check will happen every 5min.
We have 16core process
we have 15gb ram
we have 200 / partitions.
Does nagiosXI will give any impact on the server/nagios process because of every10 min check for 25000 services and 3000 check for every 5min. server performance any nagioscron jobs delay??
mbellerue
Re: Nagios check interval every 5min for 3000 every 10 min 2
Post by mbellerue »
Nagios takes care of randomizing the time that the checks actually start, that way you do not have 25000 checks starting every 10 minutes exactly. Are you running into a problem with checks not happening?
grayloglearn
As of now we haven't face any checks fail, I just want to know for future how it will behavior, if this counties checks.
benjaminsmith
Post by benjaminsmith »
Hello @grayloglearn,
Sounds good. Did you have any other questions or may we close this thread? Let us know when you have a moment.
grayloglearn
I need suggestion
Does the below resource is sufficient. for the checks (28000 services out of this 25000 services checks will happen every10min.
3000 check will happen every 5min)
we have 15gb ram
benjaminsmith
Hello @GrayLogLearn,
What type of checks are these as some plugins require more CPU resources than others? The RAM looks good, but you may want to bump up the number for CPU Cores. If this is a VM you can add more cores if needed.
If you haven't already read this, here's our guide for increasing performance.
Maximizing Performance In Nagios XI
grayloglearn
Actually i am bit confusing for the document. Please find the attachment by seeing those does our nagios server is under safe or anything we need to takecare??.
If you need more details let me know.
These all look good.
