Hello
is it possible to change the configuration wizard this way that if i add a new host/services then: "Send alert notifications to" checkbox would not be chosen for "Myself"? If it possible, will it be overwritten with next Nagios update?
Thank you.
wizard notification checkbox
Re: wizard notification checkbox
You can save this as a Wizard Template as described starting on page 7 here
That way i can create new templates but isnt it possible to change this option for all the wizards already under configuration wizard?
Unfortunately this option isn't available at this time, if you would like I can submit a feature request that may be implemented in a future version if accepted by the principal architect.elinagios wrote:That way i can create new templates but isn't it possible to change this option for all the wizards already under configuration wizard?
