Hey Guys,
Looks like there is an issue with the check_memory plugin or maybe I am reading it wrong.
For example, all of my ubuntu machines are alerting on warning however, my -w threshold is 20% and -c is 10. I even tried -w 85 and -c 90, thought its maybe reading incorrectly, but still same issues.
In this example:
WARNING - 9239 / 15380 MB (%) Free Memory, Used: 6141 MB, Shared: 0 MB, Buffers: 374 MB, Cached: 3594 MB
Based on this, we certainly have more than 20% free memory, so I am not sure what should be the correct threshold here.
This is on all ubuntu 10.04-11.10 clients.
Thanks in advance for your help.
check_mem reports warnings on idle nodes
gamechanger
Re: check_mem reports warnings on idle nodes
It could be that you don't have dc on your ubuntu machine or it isn't in the expected location.
this plugin uses /usr/bin/dc
Type
If it comes back with
this isn't the problem, otherwise report the output and we can help you from there.
Type
which dcCode: Select all
/usr/bin/dc-
gamechanger
I think that did the trick..
Thanks so much, I am going to roll out DC to rest of my machines.
