API - GET objects/servicestatus or GET objects/service
awilson
Post by awilson »
Hi. I notice that the API endpoints GET objects/servicestatus and GET objects/service both return "notifications_enabled." Are the values pointing to the same information? Are they both pointing to the notifications enabled/disabled indicator in the Service Status Detail view or is the objects/service endpoint referring to the configured value in the Alert settings?
They appear to be referring to the current setting in the Service Status Detail, but I want to be certain.
Thanks!
Re: API - GET objects/servicestatus or GET objects/service
awilson wrote:They appear to be referring to the current setting in the Service Status Detail, but I want to be certain.
that is correct
awilson
Post by awilson »
Thank you.
Please close.
