How to configure NagiosXI to use proxy to reach NCPA agents
imadc
Post by imadc »
Hello Team,
How to configure NagiosXI to use proxy or middle server that will be used as a hop to reach NCPA agents
In our use case we have NagiosXI on Data-center A
NagiosXI have access to only one server in Data-center B
What is the recommended way to reach and do active checks on all servers that are hosted in Data-center B through using one server that will be ackting as a proxy or a hop to direct those active checks inside DC B from NagiosXI in DC A.
Insurity
ssax
Dreams In Code
Re: How to configure NagiosXI to use proxy to reach NCPA age
Post by ssax »
I'd probably look at doing something like mod_gearman and setting up an external gearman worker in the other data centers, please see here for more information:
https://assets.nagios.com/downloads/nag ... ios_XI.pdf
https://support.nagios.com/kb/article.php?id=484
NOTE: Make sure that you follow the "Remote Worker Considerations" and the "Host groups and Service groups​" sections from the second link above and then follow the "Disable Worker​" section from the first link once you've setup your exclude groups.
You could also use check_by_ssh to run remote commands:
https://assets.nagios.com/downloads/nag ... ng_SSH.pdf
Let me know if you have any questions or if I can clarify anything.
imadc
Post by imadc »
Thanks ssax
Want to ask if we can we install a NagiosXI server on the remote Datacenter B using the same licensee? Seem an easier option
Because form the notes of the Mod-Gearman it is not clear what need to be provisioned or run inside Datacenter B only I see what need to be executed on the NagiosXI. So not sure how the traffic will flow
Insurity
imadc
Post by imadc »
Also another alternative will Passive check be a solution to this case
Where all Remote NCPA agent will push metric and data to the remote NagiosXI
In the case of this passive checks connection required : NCPA Agents -> NagiosXI only required the reverse is not required
Is that a try statement?
mbellerue
Post by mbellerue »
You can only have 1 active instance of Nagios XI per license. You can have a backup server ready, but it can't be used for active monitoring while your primary is still in operation.
I think your best bet here is passive checks with NCPA, as you described in your last post.
