In our environment there is a remote server which is a Linux server. This server is being monitored by Nagios server.
Following is the portion of the nrpe.cfg file (last few lines of the nrpe.cfg file)
#command[check_users]=/usr/lib/nagios/plugins/check_users -w $ARG1$ -c $ARG2$
#command[check_load]=/usr/lib/nagios/plugins/check_load -w $ARG1$ -c $ARG2$
#command[check_disk]=/usr/lib/nagios/plugins/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
#command[check_procs]=/usr/lib/nagios/plugins/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
# local configuration:
# if you'd prefer, you can instead place directives here
#include=/etc/nagios/nrpe_local.cfg
# you can place your config snipplets into nrpe.d/
# only snipplets ending in .cfg will get included
include_dir=/etc/nagios/nrpe.d/
[root@host1 nrpe.d#cd /etc/nagios/nrpe.d
[root@host1 nrpe.d#pwd
/etc/nagios/nrpe.d
[root@host1 nrpe.d]# ls
command-plugins.cfg
[root@host1 nrpe.d]#cat command-plugins.cfg
command[check_memory]=/usr/lib64/nagios/plugins/ce/check_mem.pl -f -w $ARG1$ -c $ARG2$ -C
command[check_proc]=/usr/lib64/nagios/plugins/check_procs -u $ARG1$ -a "$ARG2$" -c $ARG3$
command[check_swap]=/usr/lib64/nagios/plugins/check_swap -w $ARG1$ -c $ARG2$
command[check_toptime]=/usr/lib64/nagios/plugins/ce/check_toptime
command[check_total_procs]=/usr/lib64/nagios/plugins/check_procs $ARG1$ $ARG2$
command[check_users]=/usr/lib64/nagios/plugins/check_users $ARG1$ $ARG2$
command[check_zombie_procs]=/usr/lib64/nagios/plugins/check_procs $ARG1$ $ARG2
I did not understand where from the arguments are passing to this file.
These are not passive checks. Services are in OK state.
Please help me.
Regards,
Pratapa.
Where from the arguments are passing
Re: Where from the arguments are passing
The follow the -a flag when running ./check_nrpe on the nagios server
/usr/local/nagios/libexec/check_nrpe -H YOURHOST -t 30 -c check_disk -a 20% 10% '/'Code: Select all
/usr/local/nagios/libexec/check_nrpe -h
-a, --args=LIST Optional arguments that should be passed to the command,
separated by a space. If provided, this must be the last
option supplied on the command line.
