Add another host windows server
sophisticated
Post by sophisticated »
Hi! Im a new at Nagios, yesterday I installed Nagios and i add my first host:
# WINDOWS.CFG - SAMPLE CONFIG FILE FOR MONITORING A WINDOWS MACHINE
# NOTES: This config file assumes that you are using the sample configuration
#    files that get installed with the Nagios quickstart guide.
# HOST DEFINITIONS
# Define a host for the Windows machine we'll be monitoring
# Change the host_name, alias, and address to fit your situation
define host {
    use                     windows-server,host-pnp          ; Inherit default values from a template
    host_name               ad01          ; The name we're giving to this host
    alias                   My Windows Server       ; A longer name associated with the host
    address                 192.168.3.7             ; IP address of the host
# HOST GROUP DEFINITIONS
# Define a hostgroup for Windows machines
# All hosts that use the windows-server template will automatically be a member of this group
define hostgroup {
    hostgroup_name          windows-servers         ; The name of the hostgroup
    alias                   Windows Servers         ; Long name of the group
# SERVICE DEFINITIONS
# Create a service for monitoring the version of NSCLient++ that is installed
# Change the host_name to match the name of the host you defined above
    use                     generic-service,srv-pnp
    host_name               ad01
    service_description     NSClient++ Version
    check_command           check_nt!CLIENTVERSION
# Create a service for monitoring the uptime of the server
    host_name               ad01
    service_description     Uptime
    check_command           check_nt!UPTIME
# Create a service for monitoring CPU load
    host_name               ad01
    service_description     CPU Load
    check_command           check_nt!CPULOAD!-l 5,80,90
# Create a service for monitoring memory usage
    host_name               ad01
    service_description     Memory Usage
    check_command           check_nt!MEMUSE!-w 80 -c 90
# Create a service for monitoring C:\ disk usage
    host_name               ad01
    service_description     C:\ Drive Space
    check_command           check_nt!USEDDISKSPACE!-l c -w 80 -c 90
# Create a service for monitoring the W3SVC service
    host_name               ad01
    service_description     W3SVC
    check_command           check_nt!SERVICESTATE!-d SHOWALL -l W3SVC
# Create a service for monitoring the Explorer.exe process
    host_name               ad01
    service_description     Explorer
    check_command           check_nt!PROCSTATE!-d SHOWALL -l Explorer.exe
But how can I add another host? In this same file?
I tried add anonther one host using commas. Just like:
# HOST DEFINITIONS
define host {
    host_name               ad01,ad02          ; The name we're giving to this host
    address                 192.168.3.7, 192.168.3.8             ; IP address of the host
define hostgroup {
    host_name               ad01,ad02
    host_name               ad01,ad02
    host_name               ad01,ad02
    host_name               ad01,ad02
    host_name               ad01,ad02
    host_name               ad01,ad02
    host_name               ad01,ad02
but i think it's not correct.
My 2 question:
How can I add windows PC hosts?
Thanks!
Re: Add another host windows server
Welcome to the nagios forum!
You were pretty close, each host needs it's own definition
Change this
define host {
to this
define host {
define host {
    host_name               ad02          ; The name we're giving to this host
    alias                   My Other Windows Server       ; A longer name associated with the host
    address                 192.168.3.8             ; IP address of the host
sophisticated
Yeah! While waiting for the acceptance of the topic, I managed to come up with this idea! :D but.. I have so many hosts..
I find something like this: https://mona.deltics.info/auto-discover-for-mona-3-0/ and really dont know how to use this. What i need to install? How to do it step by step?
sophisticated wrote:Yeah! While waiting for the acceptance of the topic, I managed to come up with this idea! :D but.. I have so many hosts..
Sorry I'm not familiar with that package
We do also have a commercial solution called Nagios XI that makes configuration a breeze with an easy to use interface that allow you to clone many hosts in a few clicks. It has a 60 day free trial if you want to check it out
sophisticated
Unfortunately, our company cannot afford such solutions .. We have to use free solutions. It is a state-owned company. You can close
Thanks! :D
sophisticated wrote:Unfortunately, our company cannot afford such solutions .. We have to use free solutions. It is a state-owned company. You can close
Thanks! :D
Great!
Locking thread
