Hi All,
We have configured DHCP Service in Nagios XI but we are getting an error message stating:
Error: Could not bind socket to interface eth0. Check your privileges...
Configuration:
Please find the attachment.
The permissions for the plugin are as follows:
-rwsrwxr-x 1 root nagios 211216 Jul 10 02:26 check_dhcp
Even if i run the plugin command in the server i am getting the same error:
Moderator Note: Content removed per request
Please help me in solving this issue.
Thanks in advance.
Regards,
Srinija.
Issue with DHCP Service
Re: Issue with DHCP Service
Without any additional input, check_dhcp will try to bind on eth0. Most Linux distributions moved to the Consistent Network Device Naming convention, which gives you an interface name similar to ens32, even on a machine with 1 NIC.
You will need to find out what the name of your network adapter is, and then in the $ARG1$ field, specify the network adapter. For example, if your adapter name is ens32, you would use -i ens32
