Hello Guys,
I tried to install "Nagios XI", However, after running ./fullinstall command I am getting error as "The script that failed was: './1-prereqs'"
I am new to "Nagios XI", So, Can anyone please let me know, How to solve this issue?
Following is the complete error log,
Error: Package: nagiosxi-deps-el7-5.6.8-1.noarch (/nagiosxi-deps-el7-5.6.8-1.noarch)
Requires: php-imap
Requires: php-pgsql
Requires: php-mssql
Requires: php-pdo
Requires: php-mysql
Requires: php-pecl-ssh2
Requires: php-snmp
Requires: php-gd
Requires: mod_ssl
Requires: php-xml
Requires: httpd
Requires: php-ldap
Requires: php
Requires: php-devel
Requires: php-mbstring
Requires: php-pear
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
How to solve "./1-prereqs" issue.
benjaminsmith
Re: How to solve "./1-prereqs" issue.
Hi @Rohitp,
Thanks for posting the log. There are some missing dependencies and the installer failed. What type of server are you installing on? Does it have access to the internet?
We recommend installing on a fresh, minimal system with nothing else configured to avoid package conflicts with other applications.
Run the following and try again:
If that fails, then post the output of the following command. Thanks
yum clean all
yum update
yum repolist -v
benjaminsmith
Hi @rohitp,
One more important thing. I see this is your first post and I'd like to thank you for giving Nagios XI a try. Besides the support forum, please check out our knowledgebase for useful tech tips and HowTos. And to extend product functionality, you'll find thousands of plugins and addons on the Nagios Exchange. Welcome aboard!
