Down notice, but no Up notice
philb
Post by philb »
I have a Nagios Core 3.3.1 setup. Configuration is by NConf.
Everything seems to be in pretty good shape. I'm getting Down notices, but I never get an up notice when the services return to service.
I'm using d, u, r as my choices.
Is that the correct syntax? Common problem? How do I troubleshoot this?
Thanks.
mguthrie
Re: Down notice, but no Up notice
Post by mguthrie »
Check your contact definitions as well, they also have notification options that can override the service notification options.
philb
Post by philb »
mguthrie wrote:Check your contact definitions as well, they also have notification options that can override the service notification options.
How could I have missed that!!
Thank you so much. That's exactly what was wrong. Contacts were only configured with a d. So simple!
